Just noticed that the Nav Cube is being displayed (I usually keep it turned off as its a bit annoying) but its pointing in an odd way as I'm using the world UCS with no TWISTS or anything
Any ideas as to the cause and solution??
neilyj (No connection with Autodesk other than using the products in the real world)
It's a pain in the ars and I've been complaining to autodesk for some time now. There silence tells me they have no permanent fix. A simple workaround is to edit or remove the "GEOGRAPHICLOCATION". Be careful because removing this will reset your coordinate system to "no datum". Unfortunately, if your like me, this problem continues to come back every time I open a 2013 drawing. I've read this has no effect on your coordinate system or survey data but I'm still skeptical.
I thought SP1 sorted out this "annoyance" - it may be because I'm creating a sheet set using my sheet set template which is different from my usual template.
There doesn't seem to be any problem with it though - I'll just turn it off and forget about it....
