Hello, I have a problem with the name template of my corridor surfaces. I want it to be the name of the corridor plus (C), so I'd end up with something like "2nd & 3rd avenue (C)", so, I go into:
Toolspace/Settings tab/Corridor/Commands/CorridorExtractSurfaces
Then I go into Default Name Format and the field Corridor surface name template is showing: "<[Corridor Name]> (C)"
But then, when I create a surface, the default name is something like <[Corridor Name]> - Surface - <[Next Counter]>. I don't know if I'm not looking in the wrong place or if I'm missing something.
Thanks for your help.
Solved by Jay_B. Go to Solution.
Have you also checked the "Feature Settings"?
Feature Settiings can override command settings and can be found by rt clicking on "corridor" on settings tab of toolspace>edit feature settings>default name format>corridor surface name template.
