Civil 3D Forum
Name template for corrdidor surface
2 REPLIES 2
MLopezM
270 Views, 2 Replies
Hello, I have a problem with the name template of my corridor surfaces. I want it to be the name of the corridor plus (C), so I'd end up with something like "2nd & 3rd avenue (C)", so, I go into:
Toolspace/Settings tab/Corridor/Commands/CorridorExtractSurfaces
Then I go into Default Name Format and the field Corridor surface name template is showing: "<[Corridor Name]> (C)"
But then, when I create a surface, the default name is something like <[Corridor Name]> - Surface - <[Next Counter]>. I don't know if I'm not looking in the wrong place or if I'm missing something.
Thanks for your help.
2 REPLIES 2
Jay_B
in reply to: MLopezM
Have you also checked the "Feature Settings"?
 Feature Settiings can override command settings and can be found by rt clicking on "corridor" on settings tab of toolspace>edit feature settings>default name format>corridor surface name template.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
MLopezM
in reply to: Jay_B
Perfect solution, thank you!
Rail Community
