See Image. What does this icon mean? I can't edit anything in the fields while this is active. I have closed completely out of civ3d and when opened, its still there. These nodes were just placed. See Image.
Thanks!
Solved by randcdavidson. Go to Solution.
Means the point(s) are in a locked state. Select all, or individually if only a few you want to edit, right click and select unlock
The Icon you're referring to is supposed to be a red slashed-circle, the supposedly universal symbol for NO, overlaid on a pencil, the maybe not so universal symbol for EDIT. So that means the points are non-editable. You already have the solution for changing that.
Allen
Allen Jessup
CAD Manager - Designer
