AutoCAD Civil 3D General
Active Member
Message 1 of 4 (394 Views)
NEW PRESSURE PIPE PARTS
394 Views, 3 Replies
04-25-2012 01:32 PM
I have fiddled with the "PUBLISHPARTCONTENT" command and sort know my way around.  I have found a few fire hydrant 3d dwgs to base my part on.  Do I need just the hydrant or the whole hydrant assembly like the riser and base?  Anyone out there successful with making a new part?  Especially a fire hydrant.  Do you need a dwg for each size of a part?
*Expert Elite*
BrianHailey
Message 2 of 4 (375 Views)
Re: NEW PRESSURE PIPE PARTS
04-25-2012 07:44 PM in reply to: waggs78
As far as the "drawing per part size" I belive the answer is Yes, you need a seperate 3D model for each part size. The pressure networks (at least from what I've seen) are not parametric like Pipe Networks are.
Message 3 of 4 (238 Views)
12-03-2012 08:45 AM in reply to: BrianHailey
I'm new to Civil 3d and need parts for the pressure pipes, I've looked a t what's in the sqlite files but I need sizes they do not have. I recently loaded the latest service pack hoping it would have more parts but i does not. Do you have any suggestions for where to start fora beginner?
Distinguished Mentor
Message 4 of 4 (210 Views)
12-03-2012 05:44 PM in reply to: kathy.pendergast
try here
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Pressure-Pipe-How-do-I-create-new-fittings/m-p/342011...
For future reference, please search the forum before posting.
Also please specify which version of civil 3d you are using and include service pack level and whether it is 32bit of 64bit.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
