I have something that resembles a bar code imbedded in my drawing. It doesn't show while looking at the drawing itself, but only when I print a sheet out. I've thawed and turned on all layers, and purged the drawing, but no good. A pdf is attached. Anyone have any suggestions?
Tom
Solved by Jay_B. Go to Solution.
Hi...I accepted this as a solution, so no others reply. As it turns out, it's my print-to-pdf routine that places the bars on the print. I print out directly to the plotter and no lines - to pdf, there are lines. Another thing to investigate. Thanks for answering 🙂
Tom
