Civil 3D Forum
My subassembly always is placed at right side ...
5 REPLIES 5
tonnot
2730 Views, 5 Replies
I dont know what I'm doing bad but my subassembly always is placed going to the right....
(The sub is avery basic sub.... 4 points .... 1 variable.. no targets.)
I think that the fix is a stupid thing but I dont find it....
Any help would be appreciated. Thanks
Civil 3D (2013) how much you have to improve....
5 REPLIES 5
wfberry
in reply to: tonnot
After you get the first one to the right do a second one.  Then right click the second and select SUBASSEMBLY PROPERTIES, select Parameters tab.  At the top, change Right to Left.
Bill
Windows 7 x 64 Professional
Nvidia GeForce 9800 & 8500
12 GB Ram
i7 965 @ 3.20 GHz
Corsair Force 240 GB SSD
Infrastructure Suite 2014
tonnot
in reply to: wfberry
But ... some other examples I see detects the side automatically ... Why mine does not ?
Thanks.
KMercier_C3D
in reply to: tonnot
Are you making this in Subassembly Composer? If so, make sure to set the Side input parameter to the default value of RIGHT when creating it on the right side, this will allow it to mirror to the right or left when used in Civil 3D on the appropriate side.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
tonnot
in reply to: KMercier_C3D
Thanks Kati.
I'm learning C3D using your great book !
Hi, and then two side of assembly are not similar? Can i add two side in composer? How to this?
Rail Community
