Normally there is an area where I can right-click and select 'layers' or 'layers II' or 'Draw Order' and it will add a little sub menu-palette thing with icons I can select.
They have all dissapeared and there is no gray area around the drawing area for me to right-click to add the ones I want back. Any idea?
Solved by Alfred.NESWADBA. Go to Solution.
do you mean if you have not active any of the toolbars there is no grey area for right-click to get to the other toolbars?
If so you can choose different types of how to get at least one toolbar active, then dock it, then you have a grey area:
A) type in the command line:
_TOOLBAR<ENTER> [EDIT]look to the post 2 messages below, a dash is missing here, sorry[/EDIT]
LAYER<ENTER>
_SHOW<ENTER>
B) start command CUI, select your workspace, press modify and check one of the toolbars you have on the left side of the CUI-window
Good luck, - alfred -
when I type _toolbar or toolbar, my cui dialouge box pops up.
...but yes, what you are saying about not having even one up so I get select more is my problem, I hope.
Sorry, my mistake ... a missing dash, so type in the command as this:
_-TOOLBAR
Sorry, - alfred -
I find this method easier. You'll find this in the View ribbon.
