Civil 3D Forum
Multipurpose Styles>Shape Styles edits?
3 REPLIES 3
randcdavidson
356 Views, 3 Replies
I'm using the borehole importer in the toolbox. The resulting shape files come in my profile about 25'+ wide. Anyway to narrow this down to say 5 or 6 feet in width?
3 REPLIES 3
Could you provide us more information of the settings you are trying to adjust and give us more information of what you try to achieve? In the mean time can you please try following the post from "From the ground up" blog site.http://fromthegroundup.typepad.com/from_the_ground_up/2010/12/borehole-sample-data-and-helpfile.html
It explains teh settinsg and how to import it?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
as an example the attached image shows the block (SL1) as you can see it displays about 30' in width for the profile view. I would prefer it to be about 5' in width/profile view. Any way to set this?
I know I can edit the block in the block editor and change the x scale in the properties, although this change the text width. Where is the block that the toolbox borehole importer uses for the profile view? Is the block first created once the import button is presed? I would prefer it to come in something like this
Rail Community
