Is there a way to control the number of sections per column of multiple section views in draft like when doing them in production? I am using C3D 2014.
Solved by Citadel2012. Go to Solution.
I believe you can play with the settings in the Section View Group Plot Styles, under the array tab, to accomplish what you need.
So in draft I don't have the option to control the layout to four sections high, but I can manage it in production by limiting the sections to what fits... I guess I will be using production all the time even when I just need something quick.
Just create a template that gives you the number of rows/columns you want and use that along with the Production tools. Tell it to put them all in the same file. Just because it created the layouts doesn't mean that you have to use them if you don't want to -- you can even delete the layout tabs that you don't want.
Of course, I'm assuming that you don't want to change the layout often.
Don Ireland
Engineering Design Technician
