Civil 3D Forum
Multileader with block plotting issues
0 REPLIES 0
Message 1 of 1
aaronbarnhart2002
345 Views, 0 Replies
Attached is a drawing containing various multileaders we use for callouts on our plans.  The most used one is the circle callout which uses a _TagCircle block.  If we create a new circle callout, the multileader plots fine.  If we copy the multileader to label a similar object, the resulting multileader plots the same color as the layer, as if it had a "none" plot style.  The block itself (i.e. not as part of a multileader) plots correctly, regardless if it is copied.  The other callouts (triangle, square, etc.) function correctly whether copied or not.  I cannot figure out what is difference is between the circle and the other callout blocks.  Our work-around is to put the blocks on a layer that is white, but that doesn't follow our company standards which calls for text layers to be typically yellow.  Also attached is our plot style, renamed to add a txt extension so it could be attached. Any ideas as to what I am missing? Thanks.
0 REPLIES 0
Rail Community
