I've got a multileader that gives a spot elevation at the Top of Curb and Gutter which over night has gone 20X in size in just one file. I have run an audit and it says there are errors in the text and says it fixed them, but the size remains too large. I saw a similar post to this that says to open the leader in block editor but I can't seem to do that with this type of multileader. I checked another file which uses this same multileader and there aren't any issues there.
I've posted a screen shot which shows the problem. The leader below is what the blown up leader is supposed to look like.
Is this an annotative MLeader? If so set the drawing scale to what you are plotting with and add the scale to the Mleader object with a right-click.
John Mayo
It is annotative, but I already had the scale added. Like I said it was fine yesterday, but blown up today. I'm the only person who ever worked on this file.
Thank you.
Actually I drew the bottom one with lines, circles and mtext just to show what its supposed to look like. It's not the actual multileader.
Thank you
