Civil 3D Forum
Multi-barrel pipes
3 REPLIES 3
boberdorf
885 Views, 3 Replies
Multi-barrel pipes
What the best way to draw multiple parallel pipes that cross a corridor.  In my example I have a track with 4 pipes crossing the track corridor on slightly different alignments (from perpendicular to skewed).  I have drawn the pipes on as individual pipes under the same network following advice I found on the forum.
Hwever I cannot get them all to display on the profile.  I have tried "Draw Parts in Profile" but it seems to bring up only 1 pipe.
I would appreciate any guidance on managing multiple pipes.
3 REPLIES 3
Jay_B
in reply to: boberdorf
Select Profile View>Right Click>Profile View Properties>Pipe Networks Tab.
Are pipes 1-4 all checked to display here? This is where the profile display options are managed.
If they are checked for display please post a screen capture of the pipe layout in plan view in relation to the corridor.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
boberdorf
in reply to: Jay_B
Thanks Jay,
I appreciate the response.  I am an amatuer on C3D and overlooked that setting.
Out of curiousity, is this the correct way to manage parallel pipes based on your experience?
Jay_B
If your main goal is to draw and label the pipes I don't think it matters much if you have 4 disconnected pipes in one network or create 4 separate networks.
The reason you only had one pipe display is there are 2 options to draw pipe networks in profile view
Draw part in Profile.
Draw Entire Network in Profile.
My personal preference is to draw a single part in profile. Once this is done in a file for 1 initial pipe network,
any additional networks will also appear in the listing on the Pipe Network tab of pfl view prop's.
If a busy network is drawn using entire network option there's a bunch of pipes or structures that I end up
turning off anyhow.
HTH
C3D 2018.1
C3D 2016 SP4
Rail Community
