I had a corridor that I needed to change some of the subs from an overlay widen to a full depth reconstruction. prior to replacing the overlay sub the multiple targets set to nearest worked. and now they don not. I went through each region a reassigned the targets but the cooridor is not stretching when it should.
If I take out the additional tagets it works?
This is with 2013, is this a known issue?
Your Name
Your Name
Hi Joseph,
Can you clarify which subs you are using and swapping? I see 4 potential overlay subs. Which one for full depth reconstruction?
Would it be possible to get a screen shot of the subs? Or even better, a copy of the drawing where you swapped these subs?
