Civil 3D Forum
Mtext boxes printing only as a black box
11 REPLIES 11
Message 1 of 12
ltilley
2610 Views, 11 Replies
I am unable to work this out.
I am using civil 3d 2013. When i am printing all my text masked tect boxes print as a solid black box.
I have set the text mask to "use background colour" i have not been able to find a solution anywhere else on the forums please help
Also i can print the drawing fine from a different computer without any changes to the file :S
11 REPLIES 11
Message 2 of 12
wfberry
in reply to: ltilley
I am thinking that this is a feature of the print driver but cannot recall the exact remedy.  Check out the other printer setup is all I can offer at this time.  Someone else should step in and remind us shortly.
Bill
Message 3 of 12
rl_jackson
I think that the C3D Label wer exploded and you'll need to select one of the phantom rasters behide the mtext and use select similar to delete them.
Rick Jackson
Survey CAD Technician VI
Message 4 of 12
KirkNoonan
Are you using the same .pc3 file on both computers?
Message 5 of 12
ltilley
in reply to: KirkNoonan
Yes its the same on both computers
Message 6 of 12
ltilley
in reply to: rl_jackson
no phantom rasters to be found
thanks for the suggestion
Message 7 of 12
rl_jackson
Here is a test, go to option OP, and select display tab, and the select colors, change the 2D model background to from black to white. Do you the black boxes around the text? If so they text was a civil lable that was exploded. if not it's a print issue.
Rick Jackson
Message 8 of 12
I have seen this happen when printing to PDF.   Some printers don't know how to handle that kind of masking.
I normally have this masking turned off in my C3D styles.   It improves the performance of your drawing, and I run into less issues after I "Export to AutoCAD"
Gerald Hammerling
Message 9 of 12
ltilley
no black boxes
sample attached
Message 10 of 12
ltilley
How would this work? I am printing to the same printer with both computers and it doesnt work to pdf or straight to paper. The print preview also shows the boxes over the text. but no such issue on the other computer
If i did take out the text masking how do i deal with the objects over my text instead?
thanks
Message 11 of 12
KirkNoonan
For us, the black boxes are usually a function of the lines merge vs. lines overwrite in the .pc3 file. If everything is identical on the two setups, the only thing left is probably to open a support request.
Message 12 of 12
david.zavislan
Check the plot style (ctb) file.  The two computers may have different plotter colors assigned to the background color.
David Zavislan, P.E. | Wood Rodgers, Inc.
Rail Community
