Civil 3D Forum
Mtext Bullets and Lists
1 REPLY 1
CADDuser5678
362 Views, 1 Reply
I have a large body of text that is numbered and i need to break it into two separate mtext blocks.  is there any way to keep the numbering continuous between the two blocks? every time i delete the redundant text in the second mtext block it starts my numbering over.
any thoughts?
1 REPLY 1
troma
in reply to: CADDuser5678
Do you really need to break it up or can you use columns?
If you do need to break it, type the first number manually.  If your numbers are the default ones, you can type it like "9. "
That is whatever number, then a period, then tab.  You then may need to go to the end of the line, delete the return code and put it in again to renumber the next line to match.
Mark Green
Working on Civil 3D in Canada
Rail Community
