Civil 3D Forum
Mr Sid image file issue
3 REPLIES 3
rdisacks
371 Views, 3 Replies
I am trying to insert an Mr Sid file using Data Connect. I am running 2011 C3D. When I try adding the file to the dwg, it tries to execute the query, but then I get an error "There was a problem adding data to map."
The folder containing the SID file has two other files...the .sdw file and the metadata file. Is there another file missing? Or is the SID file too large...it's 1.6GB.
Do I have any options? Am I doing something wrong? thanks
3 REPLIES 3
in reply to: rdisacks
The Zip file for the Sid Should contain: *.sid,*.sdw,*.aux,*.shp,*.prj,*.dbf
Try using the Image>Insert comand and set the projectins in the popup dialog.
Jim
SurveyorLee
Have you installed the Raster Helper.  It is a free download from AutoCADD.
Jay_B
The Raster Design Object Enabler download mentioned by SurveyorLee can be found Here.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
