AutoCAD Civil 3D General
JamaL9722060
Message 1 of 14 (700 Views)
Moving profile or alignment,
700 Views, 13 Replies
10-18-2012 05:15 AM
I’m not sure why moving profile introduces a problem! Some data is missed!
What might be the reason?
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
LisaPohlmeyer
Message 2 of 14 (685 Views)
Re: Moving profile or alignment,
10-18-2012 06:50 AM in reply to: JamaL9722060
Using the Move command isn't our preferred method of editing an alignment and/or profile. We use the grip edit tools of both those objects.  Perhaps going through the tutorials on editing alignments and editing profiles would help you.  There's also some good reference material out there, AutoCAD Civil 3D 2013 Essentials and Mastering AutoCAD Civil 3D 2013 are two that we use.
Lisa Pohlmeyer
C3D 2012 SP4, holding off on C3D 2014
Please use "Accept as Solution" if this solved your issue.
AllenJessup
Message 3 of 14 (680 Views)
10-18-2012 07:03 AM in reply to: JamaL9722060
I just moved a couple of profile views in 2012. I didn't have any problem. Does the design profile still exist in the Prospector?
Allen
AllenJessup
Message 4 of 14 (678 Views)
10-18-2012 07:04 AM in reply to: JamaL9722060
Are you selecting the Design Profile or the Profile View when you do the Move?
LisaPohlmeyer
Message 5 of 14 (676 Views)
10-18-2012 07:06 AM in reply to: AllenJessup
I didn't realize it was the profile view he was moving, I thought it was the alignment or profile. I agree, moving the profile view shouldn't have any effect at all.
Lisa Pohlmeyer
Distinguished Contributor
ccookusi
Message 6 of 14 (675 Views)
10-18-2012 07:12 AM in reply to: JamaL9722060
Don't do a move with a window or window crossing on objects.
Move the "base" object by picking it, then everything attached to it will follow.
Therfore, in your situation, move the "Profile" by moving the Profile View.
Windows 7 Pro x64
Civil 3D 2015
Dell Precision T1650
i7 3770
NVIDIA Quadro 2000
SSD Boot
16 GB Ram
Message 7 of 14 (667 Views)
10-18-2012 07:59 AM in reply to: JamaL9722060
While I agree moving profile views with the grips instead of the move command is probably the better method should you need to adjust the profile view, have you regened after moving it? I have had this issue happen to me after moving a profile or section view. Some of the data appears to either get "lost in translation" or remains in the original location until I regen or regenall.
Clayton Farrow
Civil 3D 2014
Windows 7 Professional
Intel Xeon E31270 @ 3.4 GHz
8 GB, 64-bit
ccookusi
Message 8 of 14 (664 Views)
10-18-2012 08:01 AM in reply to: JamaL9722060
Yes.
You have to do a Regen
Windows 7 Pro x64
Civil 3D 2015
i7 3770
NVIDIA Quadro 2000
SSD Boot
16 GB Ram
AllenJessup
Message 9 of 14 (659 Views)
10-18-2012 08:06 AM in reply to: cfarrow
That sound like it might be a video card or version issue. I don't see that in 2012. I move a profile view and everything shows in the new location immediately.
Allen
Message 10 of 14 (651 Views)
10-18-2012 08:16 AM in reply to: AllenJessup
Allen
Come to think of it, that hasn't happened since we switched over to 2012 a few months ago. It was more common when we were in 2011.
Clayton
Clayton Farrow
Civil 3D 2014
8 GB, 64-bit
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
