Civil 3D Forum
Moving Entire Pipe Network to different horizontal datum
7 REPLIES 7
Message 1 of 8
millermccoy
2554 Views, 7 Replies
My coordinate system got moved.
Anyway to move my entire pipe network at once?
2015 Civil 3D
7 REPLIES 7
Message 2 of 8
jmayo-EE
in reply to: millermccoy
You can pick up the structures and move them en masse with the MOVE command but IME the pipes don't APPEAR to follow. You will then need to select each stc by the grip and attempt to move it without doing so to get the pipes to snap into place. I typically set the INSERT snap and grip edit the structure to place it right back where it is.
John Mayo
Message 3 of 8
millermccoy
in reply to: jmayo-EE
yeah the move command only moves the structures...
looks like no way to move all the pipes at once
2015 Civil 3D
Message 4 of 8
Jeff_M
I have done this in the past by going to the Network in Prospector, r/c choose Select which selects all structures & pipes. Then issue the Move/Rotate commands and move/rotate by the known displacement/rotation. Everything stays connected using this method.
Message 5 of 8
millermccoy
in reply to: Jeff_M
perfect...thanks!
2015 Civil 3D
Message 6 of 8
millermccoy
I see you can select the alignment to move it at the same time...nice
Anyway to change all the pipe inverts by 0.43 feet?
2015 Civil 3D
Message 7 of 8
jmayo-EE
Very cool Jeff thanks a bunch.
As for moving the pipes in Z, the OP should be able to do this with the move command and relative input.
Move, base point is any point on screen, destination point is @0,0,.43
John Mayo
Message 8 of 8
millermccoy
thanks!
that works...very nice
2015 Civil 3D
Rail Community
