I am still fairly new to C3D and currently working on our first real job.
I have done the design and have a corridor for which I have created a couple of different code set styles.
One of the styles is to show the relevant featurelines only (such as EC's, Back of Footways etc), which I want to use as a Design Xref in order for other disciplines to create their drawings (such as landscape architects etc). They only have access to normal AutoCAD.
So I need to somehow export/save the Corriodor as a normal CAD file. I have so far tried the following:
Is there a simple way to get a C3D corridor into normal CAD? I get the idea that this software runs on the basis of everyone using it in terms of drawing production and not normal CAD......
I kind of sold this software to my company on the basis that a lot of time will be saved by having everything in an AutoCAD environment and drawing production will be much faster. But so far I cant see a way to set up a simple CAD Xref from a C3D corridor. Am I missing something here? Surely this should be a fairly straightforward operation?
Thanks.
i guess my first question would be "why would you want to give everyone your drawing that you did your corridor in?"
thats what the actual "Site Plan" is for. i use my corridors for design purposes only they are not used for drawing production.
Neil your process is pretty much correct for working with Civil3d already. I suspect that you need to separate your design from your baseplan data, so that when other users xref your file all that they get is your alignment, profile and corridor model. If you have the layers set up correctly then the other users would be able to isolate only your corridor feature lines while they're working with your file. The whole point of this is that you don't export anything for other users while you're still designing.
Thanks Steve. I think that is probably the easiest solution. Thanks for the suggestions.
