Andy,
If you have a moment & don't mind,
Open Drawing2.dwg (this is from an out-of-the-box template) and erase
everything on the 0 and defpoints layers. If you try the other dwg, erase
everything on the 0 and _hide layers.
Every single contour elevation label should disappear.
Relabel the contours. The default layer should list as _hide on the Create
Contour Labels toolbar. Make sure you are set to "Label Multiple Group
Interior" with a 60 foot interval and place a couple of lines with the Group
Label Line command.
Repost if you can.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2007, LDT 2007, Raster Design 2007
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5483843@discussion.autodesk.com...
Nope. What you see in white is yours, magenta mine. I couldn't reproduce
your results.
Andy
