Active Contributor
rpichardo
Message 1 of 5 (574 Views)
Modify the vertical scale factor on the surface.
574 Views, 4 Replies
06-14-2013 07:25 AM
How can I to modify (exaggerate),  the vertical scale factor of the surface when I am seeing on the object viewer option.
troma
Message 2 of 5 (567 Views)
Re: Modify the vertical scale factor on the surface.
06-14-2013 07:59 AM in reply to: rpichardo
Edit Surface Style > Analysis > Elevations > Elevations Display Mode
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
rpichardo
Message 3 of 5 (557 Views)
06-14-2013 08:42 AM in reply to: rpichardo
I did that, but I did not see any change, I attached something where I am explaining on detail my case.
neilyj
Message 4 of 5 (550 Views)
06-14-2013 08:50 AM in reply to: rpichardo
Like this - may only work for triangles?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Contributor
jeremy.2012
Message 5 of 5 (394 Views)
10-28-2013 08:32 AM in reply to: rpichardo
http://www.cadapult-software.com/article_info.php/articles_id/119
This worked for me.  I've been wanting to look at my surfaces with a vertical exaggeration in object view and finally found a way.  Enjoy!!
