How can I to modify (exaggerate), the vertical scale factor of the surface when I am seeing on the object viewer option.
Solved by neilyj666. Go to Solution.
I did that, but I did not see any change, I attached something where I am explaining on detail my case.
Like this - may only work for triangles?
http://www.cadapult-software.com/article_info.php/articles_id/119
This worked for me. I've been wanting to look at my surfaces with a vertical exaggeration in object view and finally found a way. Enjoy!!
