Is it possible to change the parameters of a subassembly - for example in an assembly comprising several subassemblies, can I change a parameter in Subassembly.LaneOutsideSuper, for example, to vary the Lane Width from 4m at CH90 to 3.25m at CH160m and keep it at 3.25m for the rest of the corridor.
I am new to Civil3D and am having trouble finding the answer (I am still getting used to the jargon).
Solved by michael.robertson. Go to Solution.
Yes you can do this, build your corridor with your most common parameter. Once the corridor is build, right click and select "Corridor Section Editor".
When the Section Editor ribbon comes up you can select the "Parameter Editor" button change the parameter you want to be different then press the "Apply to a station range" button to set which stations you want this custom parameter to apply to.
... and you may also use a Width target (tell your subassembly to target a polyline, a feature line, a survey figure or an alignment). Usefull to control widening/narrowing of roads...
Welcome to the jargon!
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
