AutoCAD Civil 3D General
silvernich
Message 1 of 5 (432 Views)
Accepted Solution
Modelspace layer control per viewports
432 Views, 4 Replies
11-19-2012 03:25 PM
Hello all,
Is there an easy way to switch from a viewport in paperspace to modelspace and have the same layer state show up? I typically run with my paperspace set up with the layers showing how they will print (show lightweights and display plot styles) but I would like to be able to switch to model space and only see the layers that are showing in a particular viewport, to minimize manual layer isolation.
I used to know a way to do this.
P.S. I am using C3D 2011.
Civil 3D 2013, HF3.0
Windows 7, 64-bit, SP1
*Expert Elite*
AllenJessup
Message 2 of 5 (415 Views)
Re: Modelspace layer control per viewports
11-20-2012 06:06 AM in reply to: silvernich
Allen
*Expert Elite*
Message 3 of 5 (400 Views)
11-20-2012 10:08 AM in reply to: silvernich
Or you could save a Layer State in the viewport, or save a View with layer snapshot in the viewport, and restore it in the model tab.
Credit where credit is due! Give kudos or accept as solution whenever you can.
silvernich
Message 4 of 5 (391 Views)
11-20-2012 11:24 AM in reply to: AllenJessup
Allen,
This is exactly what I wanted. Thank you. Perhaps the name should not be "maximize viewport" as this bottom really does more than that.
- Nich
*Expert Elite*
AllenJessup
Message 5 of 5 (386 Views)
11-20-2012 11:31 AM in reply to: silvernich
Nich
Mine is not to reason why. Mine is to remember esoteric commands and system variables.
Allen
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
