Hello all,
Is there an easy way to switch from a viewport in paperspace to modelspace and have the same layer state show up? I typically run with my paperspace set up with the layers showing how they will print (show lightweights and display plot styles) but I would like to be able to switch to model space and only see the layers that are showing in a particular viewport, to minimize manual layer isolation.
I used to know a way to do this.
P.S. I am using C3D 2011.
Solved by AllenJessup. Go to Solution.
I think you're looking for VPMAX
Allen
Allen Jessup
CAD Manager - Designer
Or you could save a Layer State in the viewport, or save a View with layer snapshot in the viewport, and restore it in the model tab.
Mark Green
Working on Civil 3D in Canada
Allen,
This is exactly what I wanted. Thank you. Perhaps the name should not be "maximize viewport" as this bottom really does more than that.
- Nich
Nich
Mine is not to reason why. Mine is to remember esoteric commands and system variables.
Allen
Allen Jessup
