I've just installed Civil3D, 64-bit on windows 7(running on bootcamp) and am trying to insert a georeferenced raster image but have encountered some issues.
1. "Home tab>>Data panel>>>insert An Image" - The data panel is missing and it's also not found in "customize palettes"
2. Trying the data connect route does not work either: Display manager>>>Data>>>Connect To Data - There is no 'Data' option and I cannot connect to Data
Is this an installation issue maybe? Are the command line options I can try?
Help would be much appreciated!
Assuming you are using the Planning and Analysis workspace, go to the Insert tab (not home) and then on the Image panel you'll find the tool you need.
