Civil 3D Forum
Missing target
13 REPLIES 13
Message 1 of 14
Joe-Bouza
627 Views, 13 Replies
Missing target
I have yet to fully grasp the intersection wizard so I still do them the old way. I have a tee intersection where I will be placing a concrete vallet gutter in my flow path of 0.30%. As you can see in the image, I have two different elevations at the same location (not by design) the curb return assembly on the left wants to be an inch higher(wrong) than the the curb return on the right (correct) . I matched the stations in the parameter setting but can't seem to get it right. Any ideas? (Tried increasing the frequenct but the contours only get squirrellier)
Your Name
Your Name
13 REPLIES 13
Message 2 of 14
jmayo-EE
in reply to: Joe-Bouza
Image?
John Mayo
Message 3 of 14
Joe-Bouza
in reply to: jmayo-EE
my bad as they say Smiley Wink
Your Name
Your Name
Message 4 of 14
jmayo-EE
Do the target profiles have the same Z on the gutter line?
I know you know the intersection wizard would do this automatically. Run through the tutorial again or watch the videos.
http://www.youtube.com/watch?v=nhEb8MR5HbU
http://www.youtube.com/watch?v=WJC0vh0yT1U&feature=related
John Mayo
Message 5 of 14
Joe-Bouza
Sorry got under the gun. I double check I could be off by a thousandth Smiley Tongue
I give the tutes anoth look. I couldn't figure out how to hold my flow path/ EOP profile.
Your Name
Your Name
Message 6 of 14
Joe-Bouza
Dang! I'm blocked from youtube.
whats the deal with the widening alignment? do I ignore, where do I tell it my inbound and out bound return alignments and profiles?
Your Name
Your Name
Message 7 of 14
Joe-Bouza
Ok, I'm much better off after the vids and experimenting. One thing I found helpful is to simply let the wizard create an intersection  with the default and then go into the corridor parameters to adjust offset alignment and profiles. This technique worked great except I have one quadrant in a tee that keeps disappearing when I select my minor road curb return profile and alignment. I have the minor road cl and 2 offsets that follow existing through the returns that I am creating on either side. this is legit, no?
I havent seen a video of people using ther own alignments and profiles. The wizard offsets and profiles are great for new construction, but  rehab has its confusing existing BS that we need to live with at times.
Your Name
Your Name
Message 8 of 14
jmayo-EE
"simply let the wizard create an intersection" Aboslutely.
" I have the minor road cl and 2 offsets that follow existing through the returns that I am creating on either side. this is legit, no"
Well the app really doesn't know existing from proposed. Perhaps the profile is a bit wacky? What kind of curves do you have in this profile? I have seen one type of curve mess up int's. Did you try to recreate the profile? Maybe try a simple Free Vertical Curve (Parameter) if you have a different type of VC.
"but  rehab has its confusing existing BS that we need to live with at times." You need to make everyone else's mistakes work. 😉
John Mayo
Message 9 of 14
Joe-Bouza
What I mean by follw existing is I have an alignment that is not perfectly paralell to the cl, and the profile is so flat I left it with grade breaks. I do have engineered returns, perhaps my minor road offset alignments  should not include the returns?
Your Name
Your Name
Message 10 of 14
jmayo-EE
I would normally keep the returns separate objects in a corridor.
John Mayo
Message 11 of 14
Joe-Bouza
How do you mean?
I have 6 alignments an profiles cls and eop, the side road eop follows the return.
Your Name
Your Name
Message 12 of 14
jmayo-EE
I try to model the returns as separate alignments/profiles just like the wizard does.
Send a file or post some more pictures.
John Mayo
Message 13 of 14
Joe-Bouza
I thought that was what I was doing. I have 6 alignments and profiles:
Main road CL and 2 eop's
side road CL and 2 eop's
Should I have 2 more seperate for the returs and let the side road offsets continue acroos the main road?
Your Name
Your Name
Message 14 of 14
jmayo-EE
Yes I would have separate alignments & profiles for each return. Not sure about the offsets. I need to see it.
John Mayo
Rail Community
