Civil 3D Forum
Missing submenus under points in settings tab
6 REPLIES 6
1Dynomike
499 Views, 6 Replies
I have a relativly new install of Civil3D 2014. It appears to be missing the submenus under points in the settings tab. How can i solve this. Here are 2 screen shots, 1 of what I have and 1 of what should be. In searching for the description keys, I found them, and others to be missing. would a reinstall solve the problem, and how do I reinstall without using an available seat. TIA
6 REPLIES 6
doni49
in reply to: 1Dynomike
Those are not sub-menus.  They're styles within your template file (or in this case, NOT in your template file).  You need to copy them over from the template that does have them.  Or use the same template.
Now I don't know enough about the diffs between 2014 and previous versions to tell you whether or not you can simply use the old template.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
1Dynomike
I see, however, the 2 screen shots are from 2 dif machines using the same template file.
doni49
The images are pretty blurry.  But they both look the same to me.  Where are the differences?
Don Ireland
1Dynomike
in reply to: doni49
Pointdump
DM,
Your first screengrabs both said "Labels Only View". Your second set of screengrabs are different. One says "Labels Only View" and the other says "Active Drawing Settings View".
I think if you change to "Master View" or "Active Drawing Settings View" you'll have your tree back.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
1Dynomike
in reply to: Pointdump
Never even noticed....that was it. Thank you much!! have a great day!
Rail Community
