AutoCAD Civil 3D General
Active Contributor
kbiggs
Message 1 of 7 (213 Views)
Missing "style" option in properties window
213 Views, 6 Replies
04-26-2012 01:31 PM
I use the Map function within Civil 3D 2012 to export municipal GIS data from shp files, for our base plans. One of the clean-up functions is to convert the text exported from GIS to an appropriate text style suitable for the project. To do this, I would select the text, use the select similar command, then update the text style in the properties window. This process has worked well when using Civil 3D 2010 and 2011, however, I have noticed in 2012 the "style" option is not available.
Not sure what I mean, have a look at the two attachments. Notice in the C3D 2012 image, there is no "style" option, while the C3D 2010 image includes the 'style" option. I submitted this bug to our reseller, who was able to replicate this error. Our reseller submitted this to Autodesk, who was also able to replicate this error. What is interesting is if I open the drawing that contains the map exported data from C3D 2012 in either 2010 or 2011 versions, the "style" option is available, just not in 2012. This leads me to believe the issue is not with the data or the export functionality of 2012, the issue is with 2012 displaying the data property. Autodesk has forwarded this issue to their developers, no indication of when or if it will be resolved for Civil 3D 2012.
My workaround for now is to use Civil 3D 2010 for the drawing cleanup functions. Fortunately I am able to have previous versions of Civil 3D installed, since I am on subscription. My advice is when upgrading, do not remove your previous versions if you are on subscription, you may need to use it one day.
Keith Biggs
CAD Tech Coordinator
R.F. Binnie & Associates Ltd.
tcorey
Message 2 of 7 (201 Views)
Re: Missing "style" option in properties window
04-26-2012 02:09 PM in reply to: kbiggs
Hi Keith,
Can you post a sample drawing that we can take a look at? When I select just text items in 2012, the Properties dialog does include Style, so maybe I can glean some info by looking at your specific data.
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Contributor
kbiggs
Message 3 of 7 (198 Views)
04-26-2012 02:36 PM in reply to: kbiggs
Sure, have a look at the attached drawing. Select any text, the open the properties window in Civil 3D 2012, you should not see the 'style' option. This drawing was created using the MAPEXPORTCURRENTMAPTODWG command from the GIS SHP file data that was attached using FDO connection.
I would be interested to find out your results.
Keith Biggs
Active Contributor
nvengineer
Message 4 of 7 (193 Views)
04-26-2012 02:50 PM in reply to: kbiggs
I can't comment on the cause, but an audit repaired 27 errors and now the style selction shows up for me in C3D 2012.  Hopefully that can at least be used as a workaround.
tcorey
Message 5 of 7 (189 Views)
04-26-2012 03:03 PM in reply to: kbiggs
Those objects have a style called "", which means the style has no name.
Using the attached lisp routine, you can select the text objects (or just window the whole drawing because the ssget function filters for text objects only), type in the name of an existing text style and all selected text objects will be updated to use that style. Now the style will display in Properties and Quick Properties.
The lisp file is called ChangeTextStyle.lsp. After loading with Appload, just type chstyle at the command prompt to run it.
Best regards,
Tim
Tim Corey, Owner
Redding, CA
Active Contributor
kbiggs
Message 6 of 7 (182 Views)
04-26-2012 03:45 PM in reply to: nvengineer
Interesting that you found errors, must be a function of exporting the data from Map. I asked our reseller to use the municipal SHP file data and export this to a drawing file. The reseller had the same results as I did, as did Autodesk. Could be an issue with the export function that is creating the errors. Thanks for the help.
Keith Biggs
Active Contributor
kbiggs
Message 7 of 7 (181 Views)
04-26-2012 03:46 PM in reply to: tcorey
Thanks for the LISP routine Tim, this will help our drawing cleanup process.
Keith Biggs
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
