This may be my last post from a newsreader....if so, see you all on the
other side, maybe.
Lynn, I found this in the Update 3 readme:
After you apply this update, you may experience the following ribbon
customization-related problems:
An Incorrect or Missing Ribbon Tab
Known Issue: When you display a ribbon tab from a partial or Enterprise CUI
file, on the ribbon, the ribbon tab displays incorrectly or is missing.
Workaround: To correctly display a ribbon tab, recreate the workspace used
to display the ribbon tab from scratch. Do not duplicate or attempt to
update the workspace. Once you create a new workspace, set the workspace
current. The ribbon tab should display correctly.
So I built a new Menu, using the Acad.cui as a template. Then unloaded all
menus, loaded the new menu, then loaded the acad & civil cui's as partial
menus. I created a new workspace in that new menu. Then added the toolbars &
menus from the Civil.cui and the Ribbon tabs from the Acad.cui. Everything
now looks and works correctly (it appears after 5 minutes of testing).
Hope you see this before the groups go down for updating this afternoon.
Jeff
"Jeff Mishler" wrote in message
news:6402133@discussion.autodesk.com...
> As far as I know, this was just an unfinished item. I never tried to
> extensively use the Ribbon until 2010 so never looked into trying to fix
> that, sorry. If you do find a solution, be sure to post back because I do
> know a few others have asked the same thing.
> Good Luck!
> "erickson123" wrote in message news:6402102@discussion.autodesk.com...
>> Thanks Jeff,
>> Yes, I actually use the old Mtext editor myself, but some of my other
>> users want to start using the ribbon and I am just trying to figure out
>> why this is happening. Do you know where to find it in the cui? maybe I
>> can look there for a clue to the problem.
>> Lynn
