Hello, i have created a data band in profile view that should show a created profiles elevation, but some of the the data fields are missing irregulary. Also in the data band that shoud show the diferenece betven the tow profiles - EG and the new profile the data is missing. The EG profiles data and the surface are ok all is shown. What could be the problem ?
Hi
Could anyone offer a suggestion to this issue. I have exactly the same problem where a profile (created by a surface) is missing data where there is definately data. Most of the data is there it is just one or two stations which have not populated with elevations at those points. Not that i needed to but I checked there is a surface elevation there by running the inquiry profile tool for those stations missing data. So why would they not populate?
Cheers
Ben
c3d 2013
xp
Which surfaces are you targeting in the band settings? Check the text value for surface definition as I sometimes use surface 1 to control level markers where surface 1 gradebreaks are.
