AutoCAD Civil 3D General
Member
sbartels
Message 1 of 10 (1,081 Views)
Missing Workspaces -- Definitely
1081 Views, 9 Replies
05-17-2013 12:59 PM
I'm missing workspaces.  I open the AutoCAD Civil3D 2013 shortcut, but the only workspaces available to me are the Drafting & Annotation, Basic 3D, 3D Modeling and AutoCAD Classic.
Unfortunately, none of these allow me to create surfaces, alignments or profiles.  The Create Design panel just doesn't exist in these workspaces.
Is there any way to get the correct workspaces?  Or add the features I need into the workspaces available to me?
Thank you,
Stephanie
rkmcswain
Message 2 of 10 (1,078 Views)
Re: Missing Workspaces -- Definitely
05-17-2013 01:19 PM in reply to: sbartels
Sounds like maybe your CUIX is hosed, the WS might have been deleted?
Have you went into the CUI command to see?
Maybe you could reset or restore you CUIX file.
Here's how:
http://thecadgeek.com/blog/2009/08/reset-cui-verses-restore-cui-whats-the-difference/
Member
sbartels
Message 3 of 10 (1,074 Views)
05-17-2013 01:31 PM in reply to: rkmcswain
I tried the "Reset CUIX" command and it did wipe out my workspace customizations (back to the default settings), but it did not give me a Civil 3D workspace.
I have also looked for the tools that should be available in the Civil 3D workspace, but they aren't in the customize workspace dialog.
Stephanie
tcorey
Message 4 of 10 (1,060 Views)
05-17-2013 01:59 PM in reply to: sbartels
Open AutoCAD. Go to Options command. Profile tab, select <<C3D Imperial>> and press Set Current.
If that doesn't help, run a Repair Installation.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Member
sbartels
Message 5 of 10 (1,057 Views)
05-17-2013 02:02 PM in reply to: tcorey
My profile was set to <<C3D_Imperial>>.  I'll try to repair install tomorrow.
rkmcswain
Message 6 of 10 (1,048 Views)
05-17-2013 02:37 PM in reply to: sbartels
If you have a few minutes, log on as a different (preferably new to that machine) user and launch C3D.
Does it work?
Member
sbartels
Message 7 of 10 (1,007 Views)
05-21-2013 12:45 PM in reply to: sbartels
Okay, so we found a solution:
Under Options - Files - Customization Files - Main Customization File
Browse to Autodesk/C3D 2013/enu/Support/C3D.cuix  to select that cuix file as the main customization.
This will give access to the Civil 3D workspace.
Yay!
rkmcswain
Message 8 of 10 (984 Views)
05-22-2013 10:55 AM in reply to: sbartels
So what _was_ the loaded main menu file?
Member
sbartels
Message 9 of 10 (980 Views)
05-22-2013 11:12 AM in reply to: rkmcswain
Sorry, I didn't check.  I kicked myself for it right after  the correct one loaded.
Jay_B
Message 10 of 10 (934 Views)
06-06-2013 08:47 AM in reply to: rkmcswain
Just found this thread searching because I did a reset of the <<C3D_Imperial>> profile in 2013 c3d (Infrastructure design suite) no separate vanilla cad install in play here and it got rid of my Civil 3D workspace as an option in "workspace switching" under that profile.
The file path in my case had been reset to C:\Users\brubble\appdata\roaming\autodesk\c3d 2013\enu\support\acad
Browsing to Autodesk/C3D 2013/enu/Support/C3D.cuix as suggested fixed it and repopulates the path to
C:\Users\brubble\appdata\roaming\autodesk\c3d 2013\enu\support\c3d
Momentarily got the "The Ribbon does not have any tabs or panels currently" message but selecting the Civil 3d workspace restored the ribbon.
Jay
C3D 2014 SP1
Win 7 Professional 64 Bit
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
