AutoCAD Civil 3D General
*Expert Elite*
sboon
Message 11 of 23 (150 Views)
Re: Mill and Overlay Parameters
12-19-2013 02:15 PM in reply to: sboon
I've read through this thread several times and I'm getting even more confused.  You start from an profile elevation at the inside edge and you have a fixed outside thickness of 2"  If the slope between those two points is 1.25% plus or minus 0.25% then you're OK, otherwise the outside thickness must change - correct?  I'm not sure why you say that you would not use the profile in that case.
We may need a sketch here.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Active Member
Message 12 of 23 (149 Views)
12-19-2013 02:16 PM in reply to: sboon
Crown Height is the term I should have used. I need to connect it to the centerline design profile. I dont get the same variables as you. I am using 2011 so mine appear different.
thanks
Active Member
Message 13 of 23 (146 Views)
12-19-2013 02:32 PM in reply to: sboon
Hear is a sketch, I hope this helps.... I dont think I am explaining myself vary well. Please bear with me.
thanks
*Expert Elite*
sboon
Message 14 of 23 (129 Views)
12-19-2013 02:55 PM in reply to: VernS
Don't worry about it.  I'm working on some early Christmas cheer here, so there isn't much you can say to annoy me today.
I've got an idea for using generic links and some conditional test subs to do this, but it needs to percolate in my head for a while.  Are your lane widths fixed or variable offsets?
Steve
Active Member
Message 15 of 23 (126 Views)
12-19-2013 03:00 PM in reply to: sboon
yes, lane widths are fixed. thanks for all your help. Enjoy the rest of your evening.
*Expert Elite*
Joe-Bouza
Message 16 of 23 (119 Views)
12-19-2013 05:32 PM in reply to: sboon
wouldn't the height above be the profile of the edge?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Mentor
fcernst
Message 17 of 23 (107 Views)
12-19-2013 06:29 PM in reply to: VernS
If the lane widths are always fixed then it's easy.
Create a level horizontal generic link from the Assembly attachment point that is the CL profile elevation, out to the lane width offset, and test that location with the Conditional Cut/Fill subassembly for the Fill depth range that will effect your desired cross slope range.
Ernst Engineering
Fred Ernst, PE
C3D 2015
W7x64; i7 8gb; Radeon HD 5700
www.ernstengineering.com
Active Member
Message 18 of 23 (97 Views)
12-19-2013 09:13 PM in reply to: fcernst
I think this will work. I will mark as solution accepted as soon as I give it a try tomorrow at the office. Thanks to everyone for all the suggestions
*Expert Elite*
sboon
Message 19 of 23 (92 Views)
12-19-2013 10:12 PM in reply to: VernS
It looks like this isn't going to work.  I cannot get the Overlay sub to work when it is inserted after a Conditional sub - no idea of why.
Steve
Active Member
Message 20 of 23 (57 Views)
12-20-2013 09:42 AM in reply to: sboon
I am not having any luck either. I am not able to get a slope from a link to marked point in 2011. Maybe it will work in a newer version.
Thanks to everyone for the ideas to try.
Merry Christmas
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
