Civil 3D Forum
Migrating Points from LDD toCivil 3D
2 REPLIES 2
181 Views, 2 Replies
I am trying to migrate a LDD project to a Civil 3D project. I can't get the existing points that are in my LDD project to the Civil 3D project. Should these existing points show up in my new Civil 3D project?
2 REPLIES 2
For the present time, points have to be in a drawing that is attached to a project. To get LDT points into a project, do the following: Points menu > Create Points > [Category:] Import Points > [Command:] External Project Point Database -- Henry Sanders Autodesk ISD Civil Test Development "dunganeng" wrote in message news:19379251.1074003820317.JavaMail.jive@jiveforum1.autodesk.com... > I am trying to migrate a LDD project to a Civil 3D project. I can't get the existing points that are in my LDD project to the Civil 3D project. Should these existing points show up in my new Civil 3D project?
I forgot to mention, that once the Points are in the Project Drawing, they then need to be added to the Project using the following steps: Select the Drawing Point node Select the Points in the item list and right click Select Add to Project and chose the desired option from the Check in options. -- Henry Sanders Autodesk ISD Civil Test Development "dunganeng" wrote in message news:19379251.1074003820317.JavaMail.jive@jiveforum1.autodesk.com... > I am trying to migrate a LDD project to a Civil 3D project. I can't get the existing points that are in my LDD project to the Civil 3D project. Should these existing points show up in my new Civil 3D project?
Rail Community
