AutoCAD Civil 3D General
*Expert Elite*
AllenJessup
Message 11 of 15 (108 Views)
Re: Metric surface thinks it's imperial
09-12-2013 04:57 AM in reply to: mnorton
Don't know exactly. I haven't opened up Civil this morning yet. I'll check when I have it open. Is the shape file one that is publicly available? If it is, post a link. Then we can check it out.
I had to convert a metric point cloud to imperial a couple of weeks ago. That was really painful!
Allen
*Expert Elite*
AllenJessup
Message 12 of 15 (106 Views)
09-12-2013 05:14 AM in reply to: mnorton
No setting obvious in Style. However I can duplicate your problem in reverse. In an imperial drawing if I go to Ambient Settings and change Foot to Meter in that imperial drawing. The Surface elevations come up in Metric.
I don't know if this is your problem, just that it duplicates it.
Allen
Distinguished Contributor
mnorton
Message 13 of 15 (101 Views)
09-12-2013 06:02 AM in reply to: mnorton
All,
Thank you for your efforts.  I edited the units in the projection file (changed METERS to FEET) and repeated my surface process.  (SHP import, save, attach to new drawing, query altered elements by object data, and create surface.)  The surface is in meters, my drawing is in meters, and once again all is right with the world.  Thanks again.
Mike Norton - The Civil Guy
www.thecivilguy.com
Civil 3D 2014 (64)
Windows 7 Pro (64) SP1, 16 GB
AMD Radeon HD 6900
mnorton
Message 14 of 15 (98 Views)
09-12-2013 06:08 AM in reply to: AllenJessup
Allen,
Changing the elevation parameter on the ambient settings tab is an easier solution than editing the projection file and repeating the map import process.  Thanks for your help.
www.thecivilguy.com
Civil 3D 2014 (64)
AMD Radeon HD 6900
*Expert Elite*
AllenJessup
Message 15 of 15 (92 Views)
09-12-2013 06:14 AM in reply to: mnorton
Mike,
Thanks for posting your solution. That was creative and I don't think I would have thought of that myself.
I wouldn't consider what I did a "Solution". I would never recommend changing an Ambient Setting in an imperial drawing to metric permanently. It was only a test to try and duplicate your problem.
Allen
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
