I get the attached when opening certain drawings which fails to load my acaddoc.lsp and so several useful lisps don't get loaded.
Any ides what's causing it - a successful drawing opening shows the following
Is it related to being unable to locate the project? I don't know why that would kick out your lisp, but that's what it looks like.
It seems to me that we get that "unable to locate project" message when opening a drawing on a machine that doesn't know where to look for the data shortcuts "Working Folder". It looks in the previous working folder and can't find the "Project Folder". That's why we've started putting all our "Project Folder"s into one "Working Folder".
Mark Green
Working on Civil 3D in Canada
Yes I do - is this the culprit?
Do you know for sure?? I have many other add ins as well but only have seen this recently
Thanks for trying - I can live with the hassle as it seems to just be one drawing that is affected and I can load the lisps if needed manually.
If it persists in other drawings i may need a rethink.....but as I'm on new msachine and a fresh install hopefully its an isolated occurrence
Seems to occur only when I open a template drawing (for my sheet set) that has been saved whilst in paperspace. My usual template is saved in modelspace and doesn't show this behaviour
Maybe Recover the template and save it from ModelSpace?
Allen Jessup
Allen Jessup
Engineering Specialist / CAD Manager
I'll try it
