Civil 3D Forum
Merge / Delete Surfaces.
2 REPLIES 2
sbd123
750 Views, 2 Replies
Is it possible to merge two or more adjascent / overlapping surfaces into a single surface?
Is it possible to "Delete" multiple surfaces in one go?
2 REPLIES 2
jimsoehner
in reply to: sbd123
There are at least two ways to merge two surfaces
1.  Rename the less accurate surface. Paste the more accurate surface into the renamed sufaces.
2. Create a third surface. The first thing you need to do is paste the less accurate of the two surfaces, then paste the second surface into the new surface.
Hope that helps
Jim
Joe-Bouza
in reply to: sbd123
Merge = Paste
Delete = delete; isolate and use acad delete command
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Rail Community
