Just installed 2014 Civil 3D. In 2013, I had created screen menu layout for Lite Users, where I placed the old Standard and ExpressTools Menus along the top of the CAD window, just below the Ribbon. To do this I would Rt. Click in the Grey area (just below the Ribbon and above the CAD window), and then be able to choose menus from the AutoCAD, CIVIL, or EXPRESS menu groups.
In 2014, when I Rt.Clk. in the same area, I'm not given a way to select menus to add - as in 2013.
Is there another way to manually load the Standard AutoCAD and Express menus to the screen, in adition to the Ribbon, etc?
Thanks for any help,..
Dave
Right click at the top and choose "SHow Menu Bar"
Go to Control Panel add remove programs and modify your autocad install.
Choose Add or remove features in the AutoCAD installer and install Express tools.Choose Update.
Open AutoCAD and enter the command MENULOAD
Click “Load” and then verify that the Express Tools menu loaded by checking the list of loaded menus
From the Command prompt, type Menubar and set it to 1. This turns on the pulldown menus.
Use CUI to customize a workspace, allowing you to turn on/off pulldown menus for a particular workspace.
Mark Green
Working on Civil 3D in Canada
