Civil 3D Forum
Menu utilities error: malformed list on input
3 REPLIES 3
RandyBenson
2929 Views, 3 Replies
I'm getting this error in the middle of launching Civil 3D2014 x64 hotfix1 from the uncustomized Civil 3D 2014 Imperial icon (see command history):
Loading AEC Base...
Loading AECC Base...
Loading AECC ETransmit...
Loading AEC Base Extended...
Loading AEC Core...
Loading AEC Application...
Loading AEC Project Base...
Loading AEC Base GUI...
Loading AEC Project UI...
Loading AEC Utilities...
Loading AEC Layer Manager...
Customization file loaded successfully. Customization Group: CIVIL
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: PLANNINGANALYSIS
Customization file loaded successfully. Customization Group: MODELDOC
Customization file loaded successfully. Customization Group: CONTENTEXPLORER
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: HBSI
Customization file loaded successfully. Customization Group: APPMANAGER
Customization file loaded successfully. Customization Group: FEATUREDAPPS
Customization file loaded successfully. Customization Group: SKETCHUPIMPORTSKP
Initializing...........Done.
Loading AECC Land...
Loading AECC Subentity Selection...
Loading AECC Pipe Part...
Loading AECC QTO......
Loading AECC Pipe Network...
Loading AECC Roadway...
Loading AECC Survey...
Loading AEC Schedule...
Loading AECC Plan Production...
Loading AecCivilBase...
Loading AECC Building Site...
Loading AECC Point Cloud...
Loading AECC Hydrology...
Loading AECC Pressure Pipes...
Regenerating model.
*Cancel*
Loading AECC Base Core...
Loading AECC Base UI...
Loading AECC Event Viewer...
Loading AECC Land UI...
Loading AECC QTO UI...
Loading AECC Pipe Network UI...
Loading AECC Pressure Pipes UI...
Loading AECC Roadway UI...
Loading AECC Survey UI...
Loading AECC PlanProdSvc...
Loading AECC Plan Production UI...
Loading AECC PublishSvc...
Loading AECC Publish UI...
Loading AECC AeccUiHydrology...
Loading AECC Mapcheck...
Loading AECC Mapcheck UI...
Loading AECC Building Site UI...
Loading AECC Point Cloud UI...
Loading AECC Management UI...
Loading AECC Text Component Editor UI...
Loading AECC Style Management...
Loading AECC Style Management UI...
Loading AECC Volumes Dashboard UI...
Loading AECC DataExchange UI...
Loading AECC Model UI...
AutoCAD menu utilities loaded.
AutoCAD menu utilities loaded.; error: malformed list on input
AutoCAD menu utilities loaded.*Cancel*
Command: _RIBBON
Command: COMMANDLINE
Command: EXTERNALREFERENCES
Command: Layer
Command: Toolspace
Loading AECC Land Manager Items...
Loading AECC Hydrology Manager Items...
Loading AECC Pipe Network Manager Items...
Loading AECC Pressure Pipes Manager Items...
Loading AECC Roadway Manager Items...
Loading AECC Survey Manager Items...
Loading AECC Plan Production Manager Items...
Loading AECC Building Site Manager Items...
Loading AECC Point Cloud Manager Items...
Command:
Command: properties
Command:
Command:
<clip>
Civil 3D appears to run o.k., no error messages upon opening a drawing...
Any ideas what to check?
TIA,
Randy
3 REPLIES 3
mathewkol
in reply to: RandyBenson
There is a LISP file that AutoCAD is trying to load which contains an error.
Probably a 3rd party LISP that is loading from within:
acad.lsp
acaddoc.lsp
LISP wihtin a CUIX
MNL file
Startup Suite
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
RandyBenson
in reply to: mathewkol
Hi Matt.
I know what the error means, I was hoping someone would be able to pin down the error location from its position in the -on loading- command history. I don't thinks there are any 3rd party lisps loading -- I used the default Civil 3D icon with the  " /p "<<C3D_Imperial>>"  target.
I can load both acad2014.lsp (unmodified) and acaddoc.lsp (heavily edited) without error:
<clip>
Command: APPLOAD
acad2014.lsp successfully loaded.
acaddoc.lsp successfully loaded.
Command:
<clip>
acad2014doc.lsp is unmodified.
no custom cuix's or mnl's.
Randy
Jeff_M
I would start looking at the acad.mnl file. That's where the error is listed... That being said, I installed the Hotfix and do not experience this issue.
Jeff_M, also a frequent Swamper
Rail Community
