AutoCAD Civil 3D General Discussion
Nik-D
Message 1 of 5 (164 Views)
Median Madness
164 Views, 4 Replies
02-17-2014 11:40 PM
Hi
I am trying to model a divided road with median breakes and left hand turning lanes. When the median reduces to accomodate the LH lane, the median crosses the centreline completely
I created a base corridor using LaneFromTaperedMedian
From this I created a surface from which to sample my final corridor.
My problem is at the end and start of the bull noses to the medians. At this point the elevations of the two pavements do not match and so I get a kink in my road surface. Is there a way to adjust the cross slope of the LaneFromTaperedMedian to compensate for this or is there a better way of doing this?
Nik
*Expert Elite*
LisaPohlmeyer
Message 2 of 5 (134 Views)
Re: Median Madness
02-18-2014 03:04 PM in reply to: Nik-D
I think this class at AU 2010, CV330-3P addresses what you're looking for. I checked the website and the AU 2010 files aren't available anymore. My pdf is corrupt, but I've attached the power point. Perhaps someone else has the pdf that can help you. My understanding is that this feature is broken in 2014 however. We're using 2012. You might search the board for "median", there's lots of posts.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
Nik-D
Message 3 of 5 (110 Views)
Re: Median Madness
02-19-2014 05:40 AM in reply to: LisaPohlmeyer
Hi Lisa,
I will check this out later and let you know how I got on. Thanks very much
*Expert Elite*
LisaPohlmeyer
Message 4 of 5 (95 Views)
Re: Median Madness
02-19-2014 11:37 AM in reply to: Nik-D
Also, this might help. It's an oldie but a goodie. http://crossing-the-line-with-c3d.blogspot.com/2007/12/how-to-get-that-median-subassembly.html
Lisa Pohlmeyer
Nik-D
Message 5 of 5 (90 Views)
Re: Median Madness
02-19-2014 12:23 PM in reply to: Nik-D
Hi Lisa
Thanks for the info, unfortunately the PP did not have much in it to help me and the weblog you sent was not really what I was looking for.
I have found a workaround which is a bit more involved than what I wanted but gives ok results. I just hope that the broken LaneFromTaperMedian1 gets fixed sometime.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
