The measure tool is not giving me the correct measurement. For example, I offset a line 24' and when I go to double check the distance it is off by .03. That is starting on the original line and doing a perpendicular snap to the other line. So I thought, wait a minute that can't be right, so I drew a line between the two lines and did an inquiry and it gave me 24'. I also did a dimension which also was correct. I also measured a 97' line and it was off by 3 feet. Never had issues with previous versions of Autocad as far as measuring.
Is there something I am missing? Is there a calibration for the measure tool?
Solved by zdccadtech. Go to Solution.
Mark Green
Working on Civil 3D in Canada
