I am setting different cut and fill shapes for different material and it keeps plotting the same patterns. I check the material table and the section view display tab for the shape and it all looks correct. for now I went through them manually selecting the fill shape and changin it.
Has this been discussed before.
This is in 2012
Joe Bouza
You can set up a corridor codeset to use those to see c&F in plan. if you wanted to. Not recognizing in section is the issue.
Joe Bouza
Joe Bouza
Joe Bouza
