I am using C3D 2012 SP3
When I create the matchlines in the create view frames command, the sheet numbers for next and previous
display ####. What is the problem? I have not created any sheets yet through the SSM.
So by default the matchlines display the #### until a sheet is cut. Is this correct?
Follow up question:
Can I Dref the the viewframe group and matchlines into the sheet drawing and have the matchline text display the correct sheets? I tried it and I get the #### on the sheet numbers. If not, what is the purpose of Drefing the viewframe group
