By the sounds of your description, you have GP* as the description key. If it was actually GP there should not be a match to GPNT. Can you confirm this?
I think this is an issue but I don't think it's limited to 2012.
I am marking test hole locations. I have 4 points. TP 1, TP 2, TP 3 and TP 4 TRENCH. If I make a point group and go to the Include tab, check 'With a raw description matching' and type 'TP' in the field (without quotes of course) the point group is empty after hittinh the Apply button. If I change the match to 'TP*' the points populate the group.
John Mayo
John, that is normal. "TP" as defined in the group will not match "TP 1". You need to have the * in the raw description matching. "TP" will only match if your raw descriptoin is only "TP", no numbers after it.
Steve can you attach a small DWG with a few points in it?
Thanks Matt! I have always worked with this behaivor but always thought it should work with the spaces stopping the code recognition like the keys. No big deal though the job always gets done.
John Mayo
