AutoCAD Civil 3D General
Valued Contributor
Harold_Alberto
Message 1 of 5 (257 Views)
Match lines
257 Views, 4 Replies
12-19-2013 07:35 AM
Hi All,
I created view frames and sheets for a number of alignments.
Is there a way to turn off a match line not associated with the main alignment for a particular viewport.
Please see attached to explain clearer.
Or did I missed a setting somewhere that should turn this off automatically?
Harold
Joe-Bouza
Message 2 of 5 (246 Views)
Re: Match lines
12-19-2013 07:55 AM in reply to: Harold_Alberto
put them on there own layer nad vp freeze
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Contributor
Harold_Alberto
Message 3 of 5 (202 Views)
Re: Match lines
12-20-2013 02:00 AM in reply to: Joe-Bouza
I was hoping a setting would do it rather than through layers. Thanks Joe.
Joe-Bouza
Message 4 of 5 (188 Views)
Re: Match lines
12-20-2013 05:39 AM in reply to: Harold_Alberto
There is a srtting for that. on the settings tab>> Match lines you can add a suffix or prefix to the layer name with -* , or *- and the alignment name can be appended to the match line layer
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Valued Contributor
Harold_Alberto
Message 5 of 5 (175 Views)
Re: Match lines
12-20-2013 06:34 AM in reply to: Harold_Alberto
That's the one! thanks very much. :smileyhappy:
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
