I got into this item and tried to use it, but, apart the meaning of the words, I cannot figure out how it works and what it stands for.
Every time I use it for generating Mass Haul Diagram, I got an empty diagram (flat if no borrow pit or dump site), that does not take into account the design situation (or I do not understood the menaing of it..)
Any idea?
Any experience with it?
Guido
The mass haul is the cumulative net volume plotted against chainage and a +ve gradient indicates net cut and a -ve gradient indicates net fill however their use in Civil 3D is a bit limited (and rather useless in practice for several reasons).
You should work through the tutorial exercises to allow you to get a better idea of how they work
neilyj (No connection with Autodesk other than using the products in the real world)
I liked the " ..however their use in Civil 3D is a bit limited (and rather useless in practice for several reasons)."...
Yes, what you say is the basic and it works for "total volume", also the two parts (cut and fill) works as they should, but the one I am talking about is really weird (the Total Unusable Volume).
i also went through the tutorial (+ the help, Google and here in the discussion forum9, but seems that noone ever used it (therefore noone had problems with it)
Never have - but as a traditional mass haul only depicts cut material that can be reused as acceptable fill material, then material that is unnacceptable is presumably the total unusable volume which is perhaps set up in Materials list somewhere/somehow.
As there doesn't appear to be a good explanation in the help, perhaps Autodesk don't know either...?!?!?!?!?
I've seen it calculated but I don't really see the point in showing it on a masshaul diagram. We use masshaul for most of our road designs. The graph that Civil3d produces is useful enough I guess, but it's part of the whole end area calculation system which has other flaws.
