trynders
Message 1 of 8 (725 Views)
Mask out a portion of ground line profile
725 Views, 7 Replies
02-07-2013 07:24 AM
Hi all,
I have cut a ground line in profile view.  Is there a way to "mask out" a portion of the ground line in the profile?  I need to detail some stair but the surveyors only shot the top and bottom tread.  I don't want to add points to the surface, I just want to draw the steps in and place them in the correct profile location.  And I dont want two horizontal alignments.
dasindog
Message 2 of 8 (723 Views)
Re: Mask out a portion of ground line profile
02-07-2013 07:29 AM in reply to: trynders
I never found a better way to do it than using a wipeout and changing the draw order. It's logical that you would be able to choose a start and end station for a profile from the profile view properties.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
BrianHailey
Message 3 of 8 (722 Views)
02-07-2013 07:30 AM in reply to: trynders
You can create two surface profiles. One from the beginning of the alignment to the start of the stairs and the other from the end of the stairs to the end of the alignment. You could then create a layout profile for the stairs.
Brian Hailey
CAD-1.com
My Blog
dasindog
Message 4 of 8 (717 Views)
02-07-2013 07:32 AM in reply to: trynders
I take that back. Here are the steps..
1. delete your current existing ground profile.
2. Create a profile from surface.
3. On the left under "to sample", choose the stations you want to sample up to the start of the stairs.
4. Click Add
5. repeat steps for the section after the steps.
cheers.
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
dasindog
Message 5 of 8 (716 Views)
02-07-2013 07:33 AM in reply to: BrianHailey
You beat me to it Brian.
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
trynders
Message 6 of 8 (710 Views)
02-07-2013 07:37 AM in reply to: trynders
Thanks... That was easy.  I feel I should have known that.
I love this discussion group.
Valued Contributor
C3D_TomR
Message 7 of 8 (670 Views)
02-07-2013 09:19 PM in reply to: trynders
Another option might be to add a rectangular HIDE boundary to the Existing Ground surface. This would remove that portion of the profile because there wouldn't be a surface to sample there.
--Tom
BrianHailey
Message 8 of 8 (653 Views)
02-08-2013 08:20 AM in reply to: C3D_TomR
--Tom
That would work but you have to be careful with that. If you are doing volume calculations with that surface, there will be no volumes calculated within the area of the hide boundary because there is no surface there.
What would be ideal is to simply mask a portion of the profile similar to the way you can mask a portion of the alignment.
Brian Hailey
CAD-1.com
My Blog
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
