Is there a way to hide a corridor shape pattern(s) behind a pipe network structure in a section view? I've looked in the Structure Style, tried the "Display as Solid", "Display as Boundary" (with "Enable part masking" checked) and "Display as block", as well as the different options under the Display tab, Component display of the Section View Direction. Nothing seems to allow me to mask the corridor's pavement, AB and ASB patterns when they come into contact with the structure.
I was able to hide the corridor hatch when using a structure style with the "Display as Block" option.
I used a block that had a wipeout object. I then selected all the structures in the sections and set the drawing order to front.
