Civil 3D Forum
Mark items in alignment view to display in profile view...
13 REPLIES 13
Message 1 of 14
Postmaster_G
836 Views, 13 Replies
Hello all! Civil 3D noob here... Though I have been using ACAD for about 5+ years, I have now begun using it for design by way of Civil 3D (about 3 months now).Robot tongue
Not knowing where to start makes it hard to know what to search for... so I appologize if this has been discussed previously.
I was wondering if after drawing an alignment, creating a profile, and profile view, is there a way I can mark items along the alignment so they could show up in the profile view.  I am laying out a pipeline and want to have the profile display a marker for items such as tees, elbows, reducers and other items.  The marker I would like to use will be something like the vertical style grade break markers.
Also on a side note, as each of these items will have a different name, is there a way that I can add these markers and then have each one with a unique name?
Thank you for your help!!!
-Meow
13 REPLIES 13
Message 2 of 14
troma
in reply to: Postmaster_G
Look up the command for Project Objects to Profile View.
The commandline version is PROJECTOBJECTSTOPROF
It should also show up on the ribbon when you select your profile view.
There are a number of options for the style of the projction and its label, and the elevation for it.
Mark Green
Working on Civil 3D in Canada
Message 3 of 14
Postmaster_G
in reply to: troma
That seems to work pretty well.  What type of objects can I make that can each have its own name.
I created a simple block called SPOT.  I placed it on the alignment where a given tee is located.  Then I copied and pasted that block onto the next tee.  When I project them to the profile they get named SPOT-1 and SPOT-2.  On the label I am using the object name field and it displays the name.
It would seem that doing it this way would mean I would have to ceate 200+ blocks each with its own name?
Are there other types of autocad objects that I can insert repeatedly, each one having its own name.  As far as the plan view size I would want the object to be a very small spot.
Thank you 🙂
-Meow
Message 4 of 14
troma
Do you really need distinct names, or could you use the station to distinguish between them?
Another option is to make a unique layer for each.  You can label the source object layer instead of name.
Mark Green
Message 5 of 14
Postmaster_G
in reply to: troma
I guess you are right... I only need probably 5-10 names.  TEE, REDUCER, HIGH POINT... ETC.
Perhaps I can have them as layers or object-1 object-2 and so on.
-Meow
Message 6 of 14
why didn't you project the blocks you already has as tee, hydrant, bend, etc...?
Message 7 of 14
Postmaster_G
The drawing is not a detailed drawing, it is an overall site plan.  Simple line work represents the piping.
This is what I ended up doing for now...
To label TEEs in the profile, I created a very small block (tiny circle with a tiny solid hatch) on its own layer called [4"x6"TEE].
Then I placed the block at each TEE location.
Next I would click project objects to profile.
Then I had to tediously select each block.
Then I change the label style text contents by adding in the "Source Layer"
Seems like this should be easier but it looks fine and didn't take too long.
Thanks for the advice!
-Meow
Message 8 of 14
troma
Should be easier....
Set up a label style with the right contents ahead of time.
When you go to project the block to profile view, make sure to select the right label.
If you click the column heading you can set the label for all of them at the same time.
Mark Green
Message 9 of 14
troma
in reply to: troma
You can go one step further and edit the command default settings to default to the desired marker style and label style every time you project items to profile view.
Mark Green
Message 10 of 14
Postmaster_G
in reply to: troma
Well I did get a label style setup after the first set of items had been projected.  So when the next set of items were projected, I was able to do as you said and just set them all.  The part I was hoping would be easier would be selecting all of the items between the time you click on project items to profile and when you hit enter and then select your options.  It would be nice if I could do some sort of quick select or select previous...
-Meow
Message 11 of 14
troma
I edited my acad.pgp file to make the keyboard shortcut POP for the command PROJECTOBJECTSTOPROF
That way I can select the objects first, then run the command.  (You can do they by typing the whole command too, but I like my shortcuts.)
You can use quick select or a right-click 'Select Similar', or anything else you fancy.
Mark Green
Message 12 of 14
Postmaster_G
in reply to: troma
Now that is a great suggestion!!  I changed my alias just as you had and it works great.
"POP" IS a great alias for this one 🙂
-Meow
Message 13 of 14
Postmaster_G
A lot of the items are just line work where the object type is assumed or called out (sizes etc.)
-Meow
Message 14 of 14
mabdelmesih
use command
Rail Community
